Reports |
A Report is an ActiveX component named ActiveReport, which allows viewing and printing instant values of system variables and data stored on a Database (Alarms, Historics, Queries, and Formulas). This data can be printed either in text or graphical format, and this later format is performed by using an E3Chart object.
NOTES |
•The Report object IS NOT available on 64-bit versions of E3. However, a Report can be edited on 32-bit versions of E3 Studio, which is available on 64-bit installations. •A 32-bit E3 Viewer connected to a 64-bit Server prints a Report normally. |
To use a Report, follow the next procedures.
1.Right-click the Organizer and select the Insert Report in option.
Inserting a Report
2.If needed, configure this object's properties.
