E3Browser |
An E3Browser is an ActiveX control used for viewing data stored on a database. Users can configure queries using several types of filters on data and assign colors for each column, among other settings. This object is used to view historical data, alarms, or any existing table on a database.
E3Browser
To use this feature, follow these procedures:
1.Insert an E3Browser in the project, by right-clicking the working area and then selecting the Insert - E3Browser item.
Inserting an E3Browser on a Screen
2.An E3Browser uses a Query object to help users in the process of defining queries on an application database. For more information, please check chapter Query.
3.If needed, configure E3Browser properties. Some of the properties of this object can be configured using the Properties List, without creating scripts for this. To configure any property, locate it on the Properties List and perform the necessary adjustments. Other information about this object's functionality can be found on the E3 Reference and Scripts Manual, in its corresponding chapter.
