Shortcut Keys |
Several Elipse E3 Studio functions can be accessed directly using shortcut keys. The next tables list all available shortcut keys.
Shortcut keys for Screen objects on Views
Shortcut Key |
Description |
CTRL + Plus sign (+) |
Increases zoom. This shortcut key also works at run time |
CTRL + Minus sign (-) |
Decreases zoom. This shortcut key also works at run time |
CTRL + Zero (0) or CTRL + Asterisk (*) |
Returns to a 100% zoom |
CTRL + Five (5) or CTRL + CLEAR |
Toggles between resizing the Screen to fit in the visible area and restoring the previous zoom level and scroll bar position. NOTE: The shortcut key CTRL + Five (5), on the keypad, is available only when the NUM LOCK option is disabled |
CTRL + Mouse wheel |
Increases or decreases zoom. This shortcut key also works at run time |
CTRL + HOME |
Applies the smallest zoom allowed. This shortcut key also works at run time |
CTRL + END |
Applies the largest zoom allowed. This shortcut key also works at run time |
CTRL + Comma (,) |
Applies the previous zoom available on the Zoom menu. This shortcut key also works at run time |
CTRL + Period (.) |
Applies the next zoom available on the Zoom menu. This shortcut key also works at run time |
CTRL + ENTER |
Allows editing an object inside a group, a Linear Rotation, or a Rotation Slider, as long as this object is not locked |
ESC |
Passes the context of a selection to the parent object of the selected object inside a group, a Linear Rotation, or a Rotation Slider |
Mouse wheel |
Scrolls a Screen vertically, or horizontally if only its horizontal scroll bar is visible. This shortcut key also works at run time |
SHIFT + Mouse wheel |
Scrolls a Screen horizontally, or vertically if only its vertical scroll bar is visible. This shortcut key also works at run time |
ALT + ENTER |
Opens the Properties Window |
SHIFT + F10 |
Opens the contextual menu of the selected object |
TAB |
Moves the selection to the next object in the tab order of objects, regardless of the value of the Visible property. NOTE: If the object is in an invisible layer, it is not selected, regardless of the value of the Visible property |
SHIFT + TAB |
Moves the selection to the previous object in the tab order of objects, regardless of the value of the Visible property. NOTE: If the object is in an invisible layer, it is not selected, regardless of the value of the Visible property |
Application or menu key |
DELETE |
Deletes the selected object |
Up arrow |
Moves the selected object up |
ALT + Up arrow |
Moves the selected object up in a ten times faster step |
CTRL + Up arrow |
Moves the selected Screen down |
CTRL + ALT + Up arrow |
Moves the selected Screen down in a ten times faster step |
SHIFT + Up arrow |
Decreases the size of the selected object vertically up |
SHIFT + ALT + Up arrow |
Decreases the size of the selected object vertically up in a ten times faster step |
Down arrow |
Moves the selected object down |
ALT + Down arrow |
Moves the selected object down in a ten times faster step |
CTRL + Down arrow |
Moves the selected Screen up |
CTRL + ALT + Down arrow |
Moves the selected Screen up in a ten times faster step |
SHIFT + Down arrow |
Increases the size of the selected object vertically down |
SHIFT + ALT + Down arrow |
Increases the size of the selected object vertically down in a ten times faster step |
Left arrow |
Moves the selected object to the left |
ALT + Left arrow |
Moves the selected object to the left in a ten times faster step |
CTRL + Left arrow |
Moves the selected Screen to the right |
CTRL + ALT + Left arrow |
Moves the selected Screen to the right in a ten times faster step |
SHIFT + Left arrow |
Decreases the size of the selected object horizontally to the left |
SHIFT + ALT + Left arrow |
Decreases the size of the selected object horizontally to the left in a ten times faster step |
Right arrow |
Moves the selected object to the right |
ALT + Right arrow |
Moves the selected object to the right in a ten times faster step |
CTRL + Right arrow |
Moves the selected Screen to the left |
CTRL + ALT + Right arrow |
Moves the selected Screen to the left in a ten times faster step |
SHIFT + Right arrow |
Increases the size of the selected object horizontally to the right |
SHIFT + ALT + Right arrow |
Increases the size of the selected object horizontally to the right in a ten times faster step |
F2 |
Edits the Caption or Value property of the selected object |
CTRL + Spacebar |
Adjusts the size or position of an object's selection to the nearest pixel |
SHIFT + Drag |
Selects multiple objects or adds objects to a previous selection |
SHIFT + Click |
Adds or removes an object from a selection |
Shortcut keys for Elipse E3 Studio windows
Shortcut Key |
Description |
ESC |
Returns the keyboard focus to the last opened View, if available |
CTRL + SHIFT + O |
Opens or moves the keyboard focus to the Organizer |
CTRL + SHIFT + G |
Opens or moves the keyboard focus to the Gallery |
CTRL + SHIFT + P |
Opens or moves the keyboard focus to the Properties List |
CTRL + SHIFT + C |
Opens or moves the keyboard focus to the Domain's Object Counting window |
CTRL + SHIFT + V |
Opens or moves the keyboard focus to the Domain Verifier window |
CTRL + SHIFT + F |
Opens or moves the keyboard focus to the Find window |
CTRL + SHIFT + H |
Opens or moves the keyboard focus to the Replace window |
CTRL + SHIFT + W |
Opens or moves the keyboard focus to the WatchWindow window |
Shortcut keys for grid cells in Elipse E3 Studio
Shortcut Key |
Description |
Spacebar |
Opens a contextual menu with types of Links on the Link column of the Links tab of the Properties Window or on the Edit Links window |
F4, SHIFT + F4, CTRL + F4, or ALT + Up arrow |
Opens or closes a combo box on cells that allow selecting a value from a list of values |
ALT + Up or down arrows |
Opens a combo box on cells that allow selecting a value from a list of values |
ALT + Period (.) |
Opens a window to edit a value on cells that contain the option |
CTRL + ENTER or ALT + Down arrow |
Moves the keyboard focus to the configuration window of values from Digital, Analog, Table and Multiple Links |
ESC or ENTER |
Closes the option opened by the previous shortcut keys |
Arrow keys |
Moves through cells of a grid |
Shortcut keys for script Views
Shortcut Key |
Description |
CTRL + A |
Selects all text from the current script |
CTRL + SHIFT + A |
Opens the AppBrowser |
CTRL + E |
Creates a Run Application Pick |
CTRL + F |
Opens the Find window on the text of the current script |
CTRL + H |
Opens the Replace window on the text of the current script |
CTRL + L |
Creates a Load Value Pick |
CTRL + M |
Creates an Open Modal Screen Pick |
CTRL + T |
Creates a Toggle Value Pick |
CTRL + R |
Creates a Print Report Pick |
Creates a new script on the selected object and event |
CTRL + SHIFT + Plus sign (+) |
Creates an Open Screen Pick |
F3 |
Moves to the next occurrence on the Find or Replace windows |
SHIFT + F3 |
Moves to the previous occurrence on the Find or Replace windows |
F7 |
Compiles the selected script |
ALT + F7 |
Compiles all scripts from the selected event |
CTRL + ALT + F7 |
Compiles all events from the selected object |
CTRL + Up or down arrows |
Moves the selected script up or down, respectively, on the list with the execution order of scripts of an object |
