Analog |
An Analog Link allows users to establish a conversion scale between a source and a destination variable. By using these specified values, a linear scale is performed between property and source values.
Analog Link
The available options for this Link are described on the next table.
Available options for an Analog Link
Option |
Description |
Value on Source |
Determines maximum and minimum values reached on the source |
Value on Property |
Determines maximum and minimum values reached on the property |
To use this resource, follow these procedures:
1.Right-click an object and select the Properties option.
2.Select the Links tab, click the Link column of a property, and then select the Analog Connection option.
3.In the Source column, click to indicate the property to create a reference or write down an expression in this column.
