Digital |
In a Digital Link, users can establish that, if a variable or expression in the Source column represents a digital or Boolean value, its True or False status is mapped to certain values on the destination, including a blink option or alternating values.
Digital Link
The available options for this Link are described on the next table.
Available options for a Digital Link
Option |
Description |
Value <ON> |
Specifies a value assumed by a property when the expression on the Source column returns True |
Value <OFF> |
Specifies a value assumed by a property when the expression on the Source column returns False |
Blink <ON> |
When this option is enabled, the connected property toggles between the values from the Value <ON> option and the To value <ON> option if the expression on the Source column returns True |
Blink <OFF> |
When this option is enabled, the connected property toggles between the values from the Value <OFF> option and the To Value <OFF> option if the expression on the Source column returns False |
To value <ON> |
Specifies a value assumed by a property when the expression on the Source column returns True and the Blink option is enabled |
To value <OFF> |
Specifies a value assumed by a property when the expression on the Source column returns False and the Blink option is enabled |
To use this resource, follow these procedures:
1.Right-click an object and select the Properties option.
2.Select the Links tab, click the Link column, and then select the Digital Connection option.
3.In the Source column, click to indicate a property to create a reference or write down an expression in this column.
