Properties
Properties
This Driver's properties can be configured at design time or at run time. A runtime configuration is also called an Offline Mode Configuration, and it is described on a specific topic.
At design time, this Driver can be configured using its configuration window, displayed on the next figure.
Configuration window of this Driver
To open this Driver's configuration window in Elipse E3, in Elipse Power, or in Elipse Water, double-click a Driver object on Organizer and click Driver settings Driver settings, as shown on the next figure.
Driver settings option
In Elipse SCADA, on the other hand, this Driver's configuration window can be opened by clicking Extra, on an application's Organizer.
This configuration window is divided into several tabs, some of them for IOKit library configuration, and others are Driver-specific. For this Driver, the Modbus, Operations, and Gen SOE tabs are specific. All other tabs are for IOKit library configuration, and they are not described on this Manual. For more information about IOKit library configuration, please check topic Documentation of I/O Interfaces.
The topics Modbus Tab, Operations Tab, Gen SOE Tab, and Offline Mode Configuration describe this Driver's specific tabs and also its runtime configuration, the so-called Offline Mode, using scripts.
