Offline Mode Configuration
This Driver's configurations can also be accessed at run time if it starts in Offline mode, as explained on topic Documentation of I/O Interfaces, by using the String-type parameters described on the next table.
Available parameters
Parameter
Type
ModiconModbus.ModbusMode
Integer. Possible values are 0: Modbus RTU, 1: Modbus ASCII, or 2: Modbus TCP
ModiconModbus.Olderaddr
Boolean. Possible values are 0: Data is addressed from 0 (zero) or 1: Data is addressed from 1 (one)
ModiconModbus.UseDefaultSlaveAddress
Boolean. Possible values are 0 (zero) or 1 (one)
ModiconModbus.DefaultSlaveAddress
Unsigned integer
ModiconModbus.UseSwapAddressDelay
ModiconModbus.SwapAddressDelay
Integer, with a delay interval in milliseconds. NOTE: Obsolete option kept for compatibility reasons. For new applications, please use the Inter-frame delay option on the Serial tab of IOKit library
ModiconModbus.WaitSilenceOnError
ModiconModbus.UseGatewayTCP
ModiconModbus.EnableCMSAddressing
ModiconModbus.ConfigFile
String containing a configuration file with this Driver's operations. This file can be exported and imported on the Operations tab on this Driver's configuration window
ModiconModbus.EnableReconnectAfterTimeout
Boolean. Possible values are 0: Time-out does not generate a disconnection from physical layer or 1: In case of a time-out, when in an Ethernet physical layer, this Driver performs a physical layer disconnection and a reconnection. For Modbus RTU/ASC serial protocol communications over Ethernet, the reconnection is always performed after a time-out
ModiconModbus.UseDemotion
Boolean. Possible values are 0: Disables the Auto-Demotion mode or 1: Enables the Auto-Demotion mode
ModiconModbus.DemotionTime
Integer. Defines the inactivity time, in seconds, for a Slave device that entered the Auto-Demotion mode
ModiconModbus.DemotionErrorCount
Integer. Defines the limit on the number of consecutive failures by time-out, to put a Slave device in the Auto-Demotion mode
ModiconModbus.UserTypesConfigFile
Configuration String for user-defined data types, or structures. This is the same configuration file available on this Driver's configuration window, in the User-Defined Types option
ModiconModbus.EnableGenSOERegGrouping
Boolean. Possible values are 0: Event-reading algorithm first reads control registers, and then event data or 1: Generic SOE reading is grouped to its maximum, not only reading control registers first, but also the maximum possible events
ModiconModbus.ShowOperationsInTagBrowser
Boolean. Possible values are 0: Tag Browser window displays Tag models configured by Strings, which is the default behavior, or 1: Tag Browser window displays Tag models configured numerically, which is the legacy behavior
For more information about Offline configurations at run time, please check topic Documentation of I/O Interfaces.
