Gen SOE Tab |
The goal of this tab is to concentrate configuration options for Elipse Software's Generic SOE Reading Algorithm. The next figure displays all options on this tab.
Gen SOE tab
The only configuration option currently available is Enable control and data registers grouping (default True), which enables grouping control and data registers, to perform the minimum possible number of readings. If this option is enabled (default), this Driver starts reading tables already trying to read the maximum number of protocol-allowed registers, be them control or data registers, and possibly reading the entire table in a single reading. Such procedure usually optimizes Tag scanning the same way as Superblocks, because the time spent for reading large blocks is usually less than the time needed to perform several readings of the same amount of data, although this may depend on the device. ATOS devices do not allow grouped reading of control registers and data structures, thus requiring this option to be disabled.
