Using EntryID
Using EntryID
When selecting the Check BRCB EntryID option on the Reports tab without the option of automatic files (EID), an application must perform the next procedures to work properly:
1.Create in this application, or import via Tag Browser, the EntryID Tags available in each Buffered Report and in use by this Driver. The value of this Tag is a Text-type and represents a sequence of bytes.
2.If users do not know whether a Buffered Report is in use, please check the list of BRCBs, as described on topic Reports Tab.
3.Create in this application an Internal Tag for each EntryID to sync. This Internal Tag must have its Retentive property configured to True. NOTE: Users can also perform this procedure using XObject Properties, which can have their Retentive property enabled directly.
4.Each Internal Tag, or XObject Property, must receive value changes from the corresponding EntryID via script or Link.
5.When starting this application, there must be a script that writes the value of each EntryID according to the value of the corresponding Internal Tag, which must be updated according to the value sent by the redundant station. At the end of this process, a special Tag must be written indicating that the process of writing EntryID properties ended and this Driver can resume initialization. This Tag must be configured with the next properties:
•Name: FinishedWriteEntryID
•Device: ServerName
•Item: FinishedWriteEntryID
Any writing operation is enough for this process to be accepted.
NOTE
If the option to check EntryID is configured, this Driver only resumes the initialization after writing to this Tag.
