Reports Tab
Reports Tab
Reports tab
Reports tab
Available options on the Reports tab
Option
Description
Prefer Buffered Report Control Blocks (uses Unbuffered if not available)
IEC 61850 protocol uses Report objects to notify Client applications about changes on data. Reported data are defined by users in a DataSet. Each Report can only be linked to a single DataSet and a device can have several Reports and DataSets. Please check section Prefer Buffered Report Control Blocks for more information about this option
Poll Tags not Found in any Report
When a Tag is not found in any Report, this option allows performing a cyclical reading (polling) of this Tag according to its scan rate. Remember that this method is not the most indicated nor the most efficient, because it may be subject to slow data updates and loss of fast events
Force Tag Polling Individually using N1 Parameter
A polling request for specific variables can be defined with a value different from 0 (zero) in the N1 parameter if this option is configured
Check Report Revision Mismatch
Instructs this Driver to check for the version of Reports when starting a communication. In case of incompatible versions, an update of cache files, in LD format, is then performed
User Defined Report List
If users do not want this Driver to perform an automatic search for Reports, they can define a list of Reports that must be enabled. Please check section User-Defined Report List for more information about this option
RW Report List File (.RPT)
Indicates whether the list of Reports defined in the User Defined Report List option must be saved to a file, so that the example script of section User-Defined Report List is not needed. Writing to this file can be performed automatically by writing to a Tag or by directly editing that file, which must be on the default directory of cache files, in LD format, and must have the name of the IED and an .rpt extension. Only one IED is allowed per file. Please check section Format of RPT Files for more information
Check BRCB Entry ID
By using this option, users inform that when enabling a Buffered Report (BRCB), they must configure the EntryID parameter that contains a unique identifier for each Report message processed. So, this option allows restarting an application, or when there is a switch-over of a redundant application, that a Report sends only messages not yet processed. When selecting this option, an application must keep synced the EntryID parameters of each Buffered Report in use and also perform writings during the initialization of this Driver, informing the last received value. For more information, please check topic Using EntryID
RW EntryID List File (.EID)
Indicates whether EntryID values exposed in the Check BRCB Entry ID option must be saved to a file, so that users do not need to execute scripts to retrieve or inform the value of a field during the initialization. These files are saved to the default directory of cache files, in LD format, and must have the name of the IED and an .eid extension. Only one IED is allowed per file. For more information, please check topic Using EID Files
Check BRCB TimeOfEntry
This option was deprecated and must be replaced by EntryIDs
Wait for Gtw Ref on Startup
Enables using the functionality of automatic control of EntryIDs for gateway applications. Please check topic Gateway Configuration
Copy All Values Before Reporting
If the DataSet linked to a Report contains objects with quality and timestamp after the corresponding properties, this option can be selected to avoid a notification of value to an application happens without the correct update of quality and timestamp
Auto Integrity Rpt (s)
If the informed value is different from 0 (zero), this value is used when enabling a Report as the interval that an unsolicited general interrogation (GI) message is generated by a device
Polled Integrity Report (s)
If the informed value is different from 0 (zero), this value is used to perform a Report reading by polling
Default BRCB ResvTms (s)
Default value for the ResvTms property, in seconds, used to enable Buffered Reports. This value is used in revision 2.1 of IEC 61850 standard, defining the time interval a Report stays reserved for this Client after a connection failure
Use Exclusive URCBs
Defines if, when enabling an Unbuffered Report (URCB), this Driver is set to exclusive mode, that is, the Reserved property configured to 1 (one), or not, that is, the Reserved property configured to 0 (zero). A URCB enabled in exclusive mode cannot be used by other Clients
Use Quality Change Trigger
Indicates an option of triggering by change of quality that must be used by default, when users are not using a fixed list of Reports or if the TrgOps option was not informed
Reports can be Buffered-type or Unbuffered-type. A Buffered type means that all changes on elements of a DataSet during a disconnection are stored on buffers, so that a Client application receives a notification about all those changes, as long as there is sufficient space in memory on a device and these settings are correct. This type of Report is used mainly for SOE (Sequencing of Events) data types. Unbuffered Reports, on the other hand, only store the last value in that situation. Both Reports can be configured to send events spontaneously, at cyclical intervals or to wait for a Client application to explicitly request, by polling or general interrogation (GI), data from that Report. However, users must notice the following situations:
•If two Client applications, such as two Elipse Power applications, are connected to a device, only one of those applications can connect to each Buffered Report. This is due to the fact that, when sending data, it is deleted from a Report's internal buffer
•Two or more Client applications can connect to the same Unbuffered Report, in case they are not using the exclusive usage option
This way, the Prefer Buffered Report Control Blocks option instructs this Driver, whenever a Tag enters a communication process, that is, enter in advise or in scan, to search among all Buffered Reports of a device if the specified Tag belongs to the respective DataSet of each Report.
If not found, then the Report is enabled by this Driver, if not yet, and starts receiving change notifications. Otherwise, this Driver starts to repeat the same search process, now on Unbuffered Reports for the same Tag. If found, the Report is enabled, if not yet. If the answer is negative again, a Tag can communicate in polling mode if the Poll Tags not found in any Report option is enabled.
If the Prefer Buffered Report Control Blocks option is disabled, this Driver repeats the previous procedure, but then directly searching for Unbuffered Reports and discarding the search for Buffered Reports.
•TagName: UserReportList
•Device: ServerName
•Item: UserDefinedReportList
Sub DRV_61850_AfterStart()
'The next script creates an array
'containing the configuration of a Logical Device and its corresponding Report,
'which are activated when writing to the UserReportList Tag.
'Notice that this is a two-position array.
'If users need to activate more Reports,
'configure the size of that array
  Dim arr(1)
  arr(0) = Array("LogicalDeviceName", "LLN0$BR$brcbEV101")
  arr(1) = Array("LogicalDeviceName", "LLN0$BR$brcbEV102")
  Set Cmd = Application.GetObject("DriverName.IEDName.UserReportList")
  Cmd.WriteEx(arr)
NOTE
When selecting the User Defined Report List option, this Driver only finishes the initialization process after receiving a writing to a UserReportList Tag.
Format of an RPT File
Number_Of_LogicalDevices
LogicalDeviceN; Number_Of_Reports
ReportName; ReportOption1:ReportOption1Value; ReportOptionN:ReportOptionNValue
Available options for the RPT file format
Parameter
Description
Total number of Logical Devices in this file
LogicalDeviceN;Number_Of_Reports
For each Logical Device, insert a name and how many Reports are used
ReportName
Right after the name of each Logical Device, follows a list with the Reports used and optional fields
ReportOption;ReportValue
The Optional fields table contains optional fields allowed in a file in RPT format
Optional fields
Field
Description
DatSet:DataSetName
Name of a DataSet that must be linked to a Report
TrgOps:Options
Trigger options for a Report. The Options value corresponds to a mask of 6 (six) bits with the values 0: Not used, 1: Data Change, 2: Quality Change, 3: Data Update, 4: Integrity, and 5: GI (General Interrogation)
IntgPd:Period
Period, in milliseconds, for integrity
BufTm:Value
Timing period to wait for new events before sending, after the notification of the first event to send, in milliseconds
Resv:Value
Use of URCB in exclusive mode. Possible values are 0 (zero) or 1 (one)
ResvTms:Value
Time to wait, in seconds, for a disconnection so that a BRCB is reserved for the same Client previously connected
PurgeBuf:Options
Deletes the buffer of messages. Possible values are 0: Not Set (do nothing), 1: Set Always, or 2: Set if EntryID Write Fails
RptID:RptName
Identifier of a Report
OptFlds:Options
Optional fields for a Report message. The Options value corresponds to a mask of 10 bits with the values 0: Reserved, 1: SequenceNumber*, 2: ReportTimeStamp*, 3: ReasonForInclusion*, 4: DataSetName**, 5: DataReference, 6: BufferOverflow*, 7: EntryID*, 8: ConfRevision*, and 9: Segmentation. NOTE: Fields marked with * are used by default when the OptFields field is not specified. The DataSetName field is mandatory and all other parameters are fixed and cannot be changed
Example of an RPT file.
1
Device;1
LLN0$BR$BRCB1;ResvTms:1000
User-Defined Datasets
•TagName: DeclareDSList
•Device: ServerName
•Item: DeclareClientDSList
Users must inform an array of descriptors, each descriptor containing an array with 3 (three) Elements, the name of a Logical Device, the name of a DataSet (add an @ character at the beginning of this name if volatile), and a unique index for each DataSet.
Dim arr
arr = Array("LogicalDeviceName", "DataSetName", 1)
Set Cmd = Application.GetObject("DriverName.IEDName.DeclareDSList")
Cmd.WriteEx(arr)
•TagName: PopulateDSList
•Device: ServerName
•Item: PopulateClientDSList
Users must inform an array, and each item must contain an array with 2 (two) Elements, the index of a DataSet and the name of an LN/DO/DA in the format "LogicalDevice\LN$DO$DA".
Dim arr(4)
arr(0) = Array(1, "LDName\GGIO1$ST$stval")
arr(1) = Array(1, "LDName\GGIO2$ST$stval")
arr(2) = Array(1, "LDName\GGIO3$ST$stval")
arr(3) = Array(1, "LDName\GGIO4$ST$stval")
arr(4) = Array(1, "LDName\GGIO5$ST$stval")
Set Cmd = Application.GetObject("DriverName.IEDName.PopulateDSList")
Cmd.WriteEx(arr)
Format of a CDS File
LogicalDeviceN; Number_Of_DataSets
DataSetName; NumberofMembers
MemberNames1...N
Example of a CDS file.
1
Device;1
MyDataset1;3
Device/LLN0$DC$NamPlt
Device/LLN0$ST$Mod
Device/LPHD1$DC$PhyNam
