Tag Browser
Tag Browser
Click Tag Browser Tag Browser on this Driver's toolbar in Elipse Power to open the Tag Browser window, which allows listing and dragging to this Driver the Tags identified in a device, according to the next figure.
Tag Browser window
Tag Browser window
The Tags available from driver list contains the following folders:
•IOKit: Contains standard Tags from Elipse Software's IOKit library, allowing to read or write general connection parameters and status, among others
•Online: Displays Servers declared on the IEC61850 Device Config tab. When clicking a Server, this Driver tries to communicate with a device, creating a child folder for each Logical Device (LD) found in that device. Click an LD to retrieve all respective Tags
•Offline: Displays all Servers and LDs, but clicking an LD displays Tags from LD files created in the import directory, whether from importing SCL files or by executing an application
To use these Tags in an application, drag them from the Tags available from driver list to the Tags from current project list.
NOTE
This Driver inserts in each Logical Device a Datasets folder, in which users can find all Datasets of that Logical Device referenced by any Report.
