IEC61850 Device Config Tab
This tab allows defining devices (Servers) to establish communication.
IEC61850 Device Config tab
Available options on the IEC61850 Device Config tab
Option
Description
Browse SCL Files
Tags from relays can be created online, that is, when users can communicate with relays, or offline by importing SCL files. This option opens a window to select ICD or SCD files to import. After selecting a file, for each description of relay found, an identification is created on the list of servers, and a file with the description of Logical Devices (LD) and Logical Nodes (LN) of a relay is also created, which can be imported to an application by using the Tag Browser window. In case there are no SCL files, users can configure each relay directly by using the Add, Update, and Delete options
Server
Informs the name of a device. Used only to identify a device for this Driver, mapping it to an IP address
IP
Informs an IP address of a device. Optionally, users can inform a TCP/IP port, if it is not the default port of MMS protocol, using the format [0-255].[0-255].[0-255].[0-255]:[0-65535], such as 192.168.0.10:102
Backup IP
Informs a backup IP address of a device, if available. Use the same syntax of the IP option
PSel (Presentation Selector)
Selection value for the device used by the OSI presentation layer (ISO/IEC 8823). It must be checked, if fixed, or informed in the device's configuration. Its value is usually 1 (one)
SSel (Session Selector)
Selection value for the device used by the OSI session layer (ISO/IEC 8327). It must be checked, if fixed, or informed in the device's configuration. Its values is usually 1 (one)
TSel (Transport Selector)
Selection value for the device used by the OSI transport layer (ISO/IEC 8073). It must be checked, if fixed, or informed in the device's configuration. Its value is usually 1 (one)
Rem AP ID (Remote Application Process Identification)
Identifier used by the OSI link layer OSI (ISO/OSI 8650), in ASN.1 (Abstract Syntax Notation 1) format. Indicates the format of data adopted by the AARQ (Association Request) function. Its value is usually 1,1,999,1,1 (iso.1.999.1.1)
Rem AE Qual (Remote Application Entity Qualifier)
Identifier used by the communication layer as a formatter. It must be checked, if fixed, or informed in the device's configuration. Its value is usually 12
Disable
Disables this device. Therefore, when starting this Driver, there is no communication with this device
Use Backup IP
Informs whether the backup IP address is used
Revision
Standard Revision for this IED. The available values for this option are Auto: This Driver tries to identify automatically, v1/v2: Forces revision 1 or 2, or v2.1: Forces revision 2.1
XMPP
Function not available in this version
NOTE
The topic Limitations of this Driver contains information about the maximum number of IEDs supported by this Driver.
