Commands Tab
Commands Tab
Commands tab
Commands tab
Available options on the Commands tab
Option
Description
Asynchronous Write
Allows request commands to return success immediately, without waiting for an answer, as long as its sending was successful, such as when there is an active connection. This behavior aims to facilitate operations involving sending a large number of commands, to increase general speed. However, it does not check for failures during the processing of that command on a device
Use Single Tag Command Alias
Instructs this Driver to create, during a Tag Browsing process, a single Tag to send commands. For more information, please check the next note. If this option is not selected, a Block Tag with 5 (five) Elements is then used. For more information, please check topic I/O Tags
Use Cmd Tag N1 as Check Condition
In case of using a simple Tag to send commands, this option informs whether the N1 parameter of this Tag is used to indicate a security check parameter of a command. The N1 parameter, in this case, must be a number between 0 (zero) and 3 (three), as the result of a logic OR between bits 0: INTERLOCKING and 1: SYNCHROCHECK
NOTE
When using Elipse Power as an OPC Server, a command Tag can have its reading enabled, that is, its AllowRead property configured to True. This allows this Tag to receive the initial value of the CtlVal property of the referred command object, so that an OPC Client previously knows the data type. After sending a command, this Driver returns an automatic reading for the same Tag, with the value written in case the operation is successful. This way, the WriteFeedBackMode parameter of this Driver, which indicates how a Tag receives a confirmation of an operation by keeping the written value, can be configured as 0: WaitNextRead, preferably.
