SequenceOfUnsigned8
SequenceOfUnsigned8
This XML representation of complex data is used by the following objects/properties:
•lift.makingCarCall
•networkSecurity.supportedSecurityAlgorithms
XML Schema
  <xs:complexType name="SequenceOfUnsigned8">
    <xs:sequence>
      <xs:element minOccurs="0" maxOccurs="unbounded" name="Unsigned8" type="Unsigned8" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="SequenceOfUnsigned8" />
</xs:schema>
Examples
Example 1:
  <SequenceOfUnsigned8 />
</Value>
Example 2:
  <SequenceOfUnsigned8>
    <Unsigned8>33</Unsigned8>
    <Unsigned8>34</Unsigned8>
    <Unsigned8>35</Unsigned8>
  </SequenceOfUnsigned8>
</Value>
