SequenceOfBACnetTimerState
This XML representation of complex data is used by the following objects/properties:
•timer.alarmValues
XML Schema
  <xs:complexType name="SequenceOfBACnetTimerState">
    <xs:sequence>
      <xs:element minOccurs="0" maxOccurs="unbounded" name="BACnetTimerState" type="BACnetTimerState" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="SequenceOfBACnetTimerState" />
</xs:schema>
Examples
Example 1:
  <SequenceOfBACnetTimerState />
</Value>
Example 2:
  <SequenceOfBACnetTimerState>
    <BACnetTimerState>idle</BACnetTimerState>
    <BACnetTimerState>running</BACnetTimerState>
    <BACnetTimerState>expired</BACnetTimerState>
  </SequenceOfBACnetTimerState>
</Value>
