timer.alarmValues |
Specifies any states the presentValue must equal before a TO-OFFNORMAL event is generated.
Property alarmValues of object timer can be read and written using a single IOTag.
timer-<objectAddress>.alarmValues |
<type> = 31 |
<property> = 7 |
A character string containing an XML with a value of type <SequenceOfBACnetTimerState>.
