SequenceOfBACnetPropertyIdentifier
This XML representation of complex data is used by the following objects/properties:
•accessCredential.propertyList
•accessDoor.propertyList
•accessPoint.propertyList
•accessRights.propertyList
•accessUser.propertyList
•accessZone.propertyList
•accumulator.propertyList
•alertEnrollment.propertyList
•analogInput.propertyList
•analogOutput.propertyList
•analogValue.propertyList
•averaging.propertyList
•binaryInput.propertyList
•binaryLightingOutput.propertyList
•binaryOutput.propertyList
•binaryValue.propertyList
•bitstringValue.propertyList
•calendar.propertyList
•channel.propertyList
•characterstringValue.propertyList
•command.propertyList
•credentialDataInput.propertyList
•dateValue.propertyList
•datepatternValue.propertyList
•datetimeValue.propertyList
•datetimepatternValue.propertyList
•device.propertyList
•elevatorGroup.propertyList
•escalator.propertyList
•eventEnrollment.propertyList
•eventLog.propertyList
•file.propertyList
•globalGroup.propertyList
•group.propertyList
•integerValue.propertyList
•largeAnalogValue.propertyList
•lifeSafetyPoint.propertyList
•lifeSafetyZone.propertyList
•lift.propertyList
•lightingOutput.propertyList
•loadControl.propertyList
•loop.propertyList
•multiStateInput.propertyList
•multiStateOutput.propertyList
•multiStateValue.propertyList
•networkPort.propertyList
•networkSecurity.propertyList
•notificationClass.propertyList
•notificationForwarder.propertyList
•octetstringValue.propertyList
•positiveIntegerValue.propertyList
•program.propertyList
•pulseConverter.propertyList
•schedule.propertyList
•structuredView.propertyList
•timeValue.propertyList
•timepatternValue.propertyList
•timer.propertyList
•trendLog.propertyList
•trendLogMultiple.propertyList
XML Schema
  <xs:complexType name="SequenceOfBACnetPropertyIdentifier">
    <xs:sequence>
      <xs:element minOccurs="0" maxOccurs="unbounded" name="BACnetPropertyIdentifier" type="BACnetPropertyIdentifier" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="SequenceOfBACnetPropertyIdentifier" />
</xs:schema>
Examples
Example 1:
  <SequenceOfBACnetPropertyIdentifier />
</Value>
Example 2:
  <SequenceOfBACnetPropertyIdentifier>
    <BACnetPropertyIdentifier>ackedTransitions</BACnetPropertyIdentifier>
    <BACnetPropertyIdentifier>ackRequired</BACnetPropertyIdentifier>
    <BACnetPropertyIdentifier>action</BACnetPropertyIdentifier>
  </SequenceOfBACnetPropertyIdentifier>
</Value>
