multiStateInput.propertyList |
Contains an array of property identifiers, one property identifier for each property that exists within the object. The Object_Name, Object_Type, Object_Identifier, and Property_List properties are not included in the list.
Property propertyList of object multiStateInput can be read and written using a single IOTag.
multiStateInput-<objectAddress>.propertyList |
<type> = 13 |
<property> = 371 |
A character string containing an XML with a value of type <SequenceOfBACnetPropertyIdentifier>.
