SequenceOfBACnetNodeType
This XML representation of complex data is used by the following objects/properties:
•structuredView.subordinateNodeTypes
XML Schema
  <xs:complexType name="SequenceOfBACnetNodeType">
    <xs:sequence>
      <xs:element minOccurs="0" maxOccurs="unbounded" name="BACnetNodeType" type="BACnetNodeType" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="SequenceOfBACnetNodeType" />
</xs:schema>
Examples
Example 1:
  <SequenceOfBACnetNodeType />
</Value>
Example 2:
  <SequenceOfBACnetNodeType>
    <BACnetNodeType>unknown</BACnetNodeType>
    <BACnetNodeType>system</BACnetNodeType>
    <BACnetNodeType>network</BACnetNodeType>
  </SequenceOfBACnetNodeType>
</Value>
