structuredView.subordinateNodeTypes |
Provides node type information for each member of the Subordinate_List. If the subordinate object has its own Node_Type, it is intended that the local value in this property logically override the subordinate's Node_Type unless the local value is "UNKNOWN", in which case, the subordinate's Node_Type is used. If the size of this array is changed, the size of the Subordinate_List, Subordinate_Annotations, Subordinate_Tags, and Subordinate_Relationships arrays, if present, shall also be changed to the same size. Uninitialized Subordinate_Node_Types array elements shall have the value UNKNOWN.
Property subordinateNodeTypes of object structuredView can be read and written using a single IOTag.
structuredView-<objectAddress>.subordinateNodeTypes |
<type> = 29 |
<property> = 487 |
A character string containing an XML with a value of type <SequenceOfBACnetNodeType>.
