SequenceOfBACnetNetworkSecurityPolicy
This XML representation of complex data is used by the following objects/properties:
•networkSecurity.networkAccessSecurityPolicies
XML Schema
  <xs:complexType name="SequenceOfBACnetNetworkSecurityPolicy">
    <xs:sequence>
      <xs:element minOccurs="0" maxOccurs="unbounded" name="BACnetNetworkSecurityPolicy" type="BACnetNetworkSecurityPolicy" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="SequenceOfBACnetNetworkSecurityPolicy" />
</xs:schema>
Examples
Example 1:
  <SequenceOfBACnetNetworkSecurityPolicy />
</Value>
Example 2:
  <SequenceOfBACnetNetworkSecurityPolicy>
    <BACnetNetworkSecurityPolicy>
      <PortId>33</PortId>
      <SecurityLevel>plainTrusted</SecurityLevel>
    </BACnetNetworkSecurityPolicy>
      <PortId>35</PortId>
      <SecurityLevel>encryptedTrusted</SecurityLevel>
      <PortId>37</PortId>
  </SequenceOfBACnetNetworkSecurityPolicy>
</Value>
