networkSecurity.networkAccessSecurityPolicies |
Specifies the security policy for each network directly connected to the device. It specifies the level of security that the device should use for network infrastructure services, such as Who-Is, I-Am, Who-Is-Router, etc. This array shall have 1 entry for each network port. The Port ID field shall correspond to the Port ID of the associated network. For non-routing nodes, this value shall be 0.
Property networkAccessSecurityPolicies of object networkSecurity can be read and written using a single IOTag.
networkSecurity-<objectAddress>.networkAccessSecurityPolicies |
<type> = 38 |
<property> = 332 |
A character string containing an XML with a value of type <SequenceOfBACnetNetworkSecurityPolicy>.
