SequenceOfBACnetNameValueCollection
This XML representation of complex data is used by the following objects/properties:
•structuredView.subordinateTags
XML Schema
  <xs:complexType name="SequenceOfBACnetNameValueCollection">
    <xs:sequence>
      <xs:element minOccurs="0" maxOccurs="unbounded" name="BACnetNameValueCollection" type="BACnetNameValueCollection" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="SequenceOfBACnetNameValueCollection" />
</xs:schema>
Examples
Example 1:
  <SequenceOfBACnetNameValueCollection />
</Value>
Example 2:
  <SequenceOfBACnetNameValueCollection>
    <BACnetNameValueCollection>
      <Members />
    </BACnetNameValueCollection>
      <Members>
        <BACnetNameValue>
          <Name>Abcde</Name>
          <Value>
            <Boolean>true</Boolean>
          </Value>
        </BACnetNameValue>
      </Members>
      <Members>
        <BACnetNameValue>
          <Name>Abcde</Name>
          <Value>
          </Value>
        </BACnetNameValue>
      </Members>
  </SequenceOfBACnetNameValueCollection>
</Value>
Example 3:
      <Members>
        <BACnetNameValue>
          <Name>Abcde</Name>
          <Value>
          </Value>
        </BACnetNameValue>
        <BACnetNameValue>
          <Name>Abcde</Name>
          <Value>
          </Value>
        </BACnetNameValue>
        <BACnetNameValue>
          <Name>Abcde</Name>
          <Value>
          </Value>
        </BACnetNameValue>
      </Members>
      <Members>
        <BACnetNameValue>
          <Name>Abcde</Name>
          <Value>
          </Value>
        </BACnetNameValue>
      </Members>
      <Members>
        <BACnetNameValue>
          <Name>Abcde</Name>
          <Value>
          </Value>
        </BACnetNameValue>
      </Members>
</Value>
