structuredView.subordinateTags |
Provides individual collections of tags for each of the subordinates. If the size of this array is changed, the size of the Subordinate_List, Subordinate_Annotations, Subordinate_Node_Types, and Subordinate_Relationships arrays, if present, shall also be changed to the same size. Uninitialized Subordinate_Tags array elements shall be empty collections.
Property subordinateTags of object structuredView can be read and written using a single IOTag.
structuredView-<objectAddress>.subordinateTags |
<type> = 29 |
<property> = 488 |
A character string containing an XML with a value of type <SequenceOfBACnetNameValueCollection>.
