SequenceOfBACnetLiftFault
This XML representation of complex data is used by the following objects/properties:
•lift.faultSignals
XML Schema
  <xs:complexType name="SequenceOfBACnetLiftFault">
    <xs:sequence>
      <xs:element minOccurs="0" maxOccurs="unbounded" name="BACnetLiftFault" type="BACnetLiftFault" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="SequenceOfBACnetLiftFault" />
</xs:schema>
Examples
Example 1:
  <SequenceOfBACnetLiftFault />
</Value>
Example 2:
  <SequenceOfBACnetLiftFault>
    <BACnetLiftFault>controllerFault</BACnetLiftFault>
    <BACnetLiftFault>driveAndMotorFault</BACnetLiftFault>
    <BACnetLiftFault>governorAndSafetyGearFault</BACnetLiftFault>
  </SequenceOfBACnetLiftFault>
</Value>
