lift.faultSignals |
Represents a list of values that indicates fault conditions of the lift.
Property faultSignals of object lift can be read and written using a single IOTag.
lift-<objectAddress>.faultSignals |
<type> = 59 |
<property> = 463 |
A character string containing an XML with a value of type <SequenceOfBACnetLiftFault>.
