SequenceOfBACnetLiftCarCallList
This XML representation of complex data is used by the following objects/properties:
•lift.registeredCarCall
XML Schema
  <xs:complexType name="SequenceOfBACnetLiftCarCallList">
    <xs:sequence>
      <xs:element minOccurs="0" maxOccurs="unbounded" name="BACnetLiftCarCallList" type="BACnetLiftCarCallList" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="SequenceOfBACnetLiftCarCallList" />
</xs:schema>
Examples
Example 1:
  <SequenceOfBACnetLiftCarCallList />
</Value>
Example 2:
  <SequenceOfBACnetLiftCarCallList>
    <BACnetLiftCarCallList>
      <FloorNumbers />
    </BACnetLiftCarCallList>
      <FloorNumbers>
        <Unsigned8>33</Unsigned8>
      </FloorNumbers>
      <FloorNumbers>
        <Unsigned8>34</Unsigned8>
      </FloorNumbers>
  </SequenceOfBACnetLiftCarCallList>
</Value>
Example 3:
      <FloorNumbers>
        <Unsigned8>35</Unsigned8>
        <Unsigned8>36</Unsigned8>
        <Unsigned8>37</Unsigned8>
      </FloorNumbers>
      <FloorNumbers>
        <Unsigned8>38</Unsigned8>
      </FloorNumbers>
      <FloorNumbers>
        <Unsigned8>39</Unsigned8>
      </FloorNumbers>
</Value>
