lift.registeredCarCall |
Represents the lists of currently registered car calls (requests to stop at particular floors using a particular door) for this lift. Each array element represents the list of universal floor numbers for which calls are registered for the door of the car assigned to this array element.
Property registeredCarCall of object lift can be read and written using a single IOTag.
lift-<objectAddress>.registeredCarCall |
<type> = 59 |
<property> = 480 |
A character string containing an XML with a value of type <SequenceOfBACnetLiftCarCallList>.
