SequenceOfBACnetLifeSafetyMode
This XML representation of complex data is used by the following objects/properties:
•lifeSafetyPoint.acceptedModes
•lifeSafetyZone.acceptedModes
XML Schema
  <xs:complexType name="SequenceOfBACnetLifeSafetyMode">
    <xs:sequence>
      <xs:element minOccurs="0" maxOccurs="unbounded" name="BACnetLifeSafetyMode" type="BACnetLifeSafetyMode" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="SequenceOfBACnetLifeSafetyMode" />
</xs:schema>
Examples
Example 1:
  <SequenceOfBACnetLifeSafetyMode />
</Value>
Example 2:
  <SequenceOfBACnetLifeSafetyMode>
    <BACnetLifeSafetyMode>off</BACnetLifeSafetyMode>
    <BACnetLifeSafetyMode>on</BACnetLifeSafetyMode>
    <BACnetLifeSafetyMode>test</BACnetLifeSafetyMode>
  </SequenceOfBACnetLifeSafetyMode>
</Value>
