SequenceOfBACnetLandingCallStatus
This XML representation of complex data is used by the following objects/properties:
•elevatorGroup.landingCalls
XML Schema
  <xs:complexType name="SequenceOfBACnetLandingCallStatus">
    <xs:sequence>
      <xs:element minOccurs="0" maxOccurs="unbounded" name="BACnetLandingCallStatus" type="BACnetLandingCallStatus" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="SequenceOfBACnetLandingCallStatus" />
</xs:schema>
Examples
Example 1:
  <SequenceOfBACnetLandingCallStatus />
</Value>
Example 2:
  <SequenceOfBACnetLandingCallStatus>
    <BACnetLandingCallStatus>
      <FloorNumber>33</FloorNumber>
      <Command>
        <Direction>none</Direction>
      </Command>
      <FloorText>Abcde</FloorText>
    </BACnetLandingCallStatus>
      <FloorNumber>35</FloorNumber>
      <Command>
        <Direction>up</Direction>
      </Command>
      <FloorNumber>37</FloorNumber>
      <Command>
        <Direction>upAndDown</Direction>
      </Command>
  </SequenceOfBACnetLandingCallStatus>
</Value>
