BACnetLandingCallStatus |
<xs:complexType name="BACnetLandingCallStatus">
<xs:sequence>
<xs:element name="FloorNumber" type="Unsigned8" />
<xs:element name="Command" type="BACnetLandingCallStatus_Command" />
<xs:element minOccurs="0" name="FloorText" type="CharacterString" />
</xs:sequence>
</xs:complexType>
Example 1:
<BACnetLandingCallStatus>
<FloorNumber>33</FloorNumber>
<Command>
<Direction>none</Direction>
</Command>
<FloorText>Abcde</FloorText>
</BACnetLandingCallStatus>
Example 2:
<FloorNumber>35</FloorNumber>
<Command>
<Direction>up</Direction>
</Command>
