SequenceOfBACnetEventLogRecord
This XML representation of complex data is used by the following objects/properties:
•eventLog.logBuffer
XML Schema
  <xs:complexType name="SequenceOfBACnetEventLogRecord">
    <xs:sequence>
      <xs:element minOccurs="0" maxOccurs="unbounded" name="BACnetEventLogRecord" type="BACnetEventLogRecord" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="SequenceOfBACnetEventLogRecord" />
</xs:schema>
Examples
Example 1:
  <SequenceOfBACnetEventLogRecord />
</Value>
Example 2:
  <SequenceOfBACnetEventLogRecord>
    <BACnetEventLogRecord>
      <Timestamp>
        <Date>2017-12-20</Date>
        <Time>22:39:15.980</Time>
      </Timestamp>
      <LogDatum>
        <LogStatus>
          <logDisabled>true</logDisabled>
          <logInterrupted>true</logInterrupted>
        </LogStatus>
      </LogDatum>
    </BACnetEventLogRecord>
      <Timestamp>
        <Date>2018-12-20</Date>
      </Timestamp>
      <LogDatum>
        <LogStatus>
        </LogStatus>
      </LogDatum>
      <Timestamp>
        <Date>2019-12-20</Date>
      </Timestamp>
      <LogDatum>
        <LogStatus>
        </LogStatus>
      </LogDatum>
  </SequenceOfBACnetEventLogRecord>
</Value>
