eventLog.logBuffer |
Contains a list of up to Buffer_Size timestamped log records of datatype BACnetEventLogRecord, each of which conveys the event notification parameters or status changes in the Event Log object.
Property logBuffer of object eventLog can be read and written using a single IOTag.
eventLog-<objectAddress>.logBuffer |
<type> = 25 |
<property> = 131 |
A character string containing an XML with a value of type <SequenceOfBACnetEventLogRecord>.
