SequenceOfBACnetDoorStatus
This XML representation of complex data is used by the following objects/properties:
•lift.carDoorStatus
XML Schema
  <xs:complexType name="SequenceOfBACnetDoorStatus">
    <xs:sequence>
      <xs:element minOccurs="0" maxOccurs="unbounded" name="BACnetDoorStatus" type="BACnetDoorStatus" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="SequenceOfBACnetDoorStatus" />
</xs:schema>
Examples
Example 1:
  <SequenceOfBACnetDoorStatus />
</Value>
Example 2:
  <SequenceOfBACnetDoorStatus>
    <BACnetDoorStatus>closed</BACnetDoorStatus>
    <BACnetDoorStatus>opened</BACnetDoorStatus>
    <BACnetDoorStatus>unknown</BACnetDoorStatus>
  </SequenceOfBACnetDoorStatus>
</Value>
