lift.carDoorStatus |
Indicates the status of the doors on the car. Each array element indicates the status of the car door assigned to this array element.
Property carDoorStatus of object lift can be read and written using a single IOTag.
lift-<objectAddress>.carDoorStatus |
<type> = 59 |
<property> = 450 |
A character string containing an XML with a value of type <SequenceOfBACnetDoorStatus>.
