SequenceOfBACnetCOVSubscription
This XML representation of complex data is used by the following objects/properties:
•device.activeCovSubscriptions
XML Schema
  <xs:complexType name="SequenceOfBACnetCOVSubscription">
    <xs:sequence>
      <xs:element minOccurs="0" maxOccurs="unbounded" name="BACnetCOVSubscription" type="BACnetCOVSubscription" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="SequenceOfBACnetCOVSubscription" />
</xs:schema>
Examples
Example 1:
  <SequenceOfBACnetCOVSubscription />
</Value>
Example 2:
  <SequenceOfBACnetCOVSubscription>
    <BACnetCOVSubscription>
      <Recipient>
        <Recipient>
          <Device>device-501</Device>
        </Recipient>
        <ProcessIdentifier>2346</ProcessIdentifier>
      </Recipient>
      <MonitoredPropertyReference>
        <ObjectIdentifier>device-503</ObjectIdentifier>
        <PropertyIdentifier>actionText</PropertyIdentifier>
        <PropertyArrayIndex>1238</PropertyArrayIndex>
      </MonitoredPropertyReference>
      <IssueConfirmedNotifications>true</IssueConfirmedNotifications>
      <TimeRemaining>1239</TimeRemaining>
      <CovIncrement>1240.567749</CovIncrement>
    </BACnetCOVSubscription>
      <Recipient>
        <Recipient>
          <Device>device-508</Device>
        </Recipient>
        <ProcessIdentifier>2353</ProcessIdentifier>
      </Recipient>
        <ObjectIdentifier>device-510</ObjectIdentifier>
        <PropertyIdentifier>apduSegmentTimeout</PropertyIdentifier>
        <PropertyArrayIndex>1245</PropertyArrayIndex>
      <TimeRemaining>1246</TimeRemaining>
      <CovIncrement>1247.567749</CovIncrement>
      <Recipient>
        <Recipient>
          <Device>device-515</Device>
        </Recipient>
        <ProcessIdentifier>2360</ProcessIdentifier>
      </Recipient>
        <ObjectIdentifier>device-517</ObjectIdentifier>
        <PropertyIdentifier>notificationClass</PropertyIdentifier>
        <PropertyArrayIndex>1252</PropertyArrayIndex>
      <TimeRemaining>1253</TimeRemaining>
      <CovIncrement>1254.567749</CovIncrement>
  </SequenceOfBACnetCOVSubscription>
</Value>
