device.activeCovSubscriptions |
Provides a network-visible indication of those COV subscriptions that are active at any given time. Whenever a COV Subscription is created with the SubscribeCOV or SubscribeCOVProperty service, a new entry is added to the Active_COV_Subscriptions list. Similarly, whenever a COV Subscription is terminated, the corresponding entry shall be removed from the Active_COV_Subscriptions list.
Property activeCovSubscriptions of object device can be read and written using a single IOTag.
device-<objectAddress>.activeCovSubscriptions |
<type> = 8 |
<property> = 152 |
A character string containing an XML with a value of type <SequenceOfBACnetCOVSubscription>.
