SequenceOfBACnetAuthorizationExemption
This XML representation of complex data is used by the following objects/properties:
•accessCredential.authorizationExemptions
XML Schema
  <xs:complexType name="SequenceOfBACnetAuthorizationExemption">
    <xs:sequence>
      <xs:element minOccurs="0" maxOccurs="unbounded" name="BACnetAuthorizationExemption" type="BACnetAuthorizationExemption" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="SequenceOfBACnetAuthorizationExemption" />
</xs:schema>
Examples
Example 1:
  <SequenceOfBACnetAuthorizationExemption />
</Value>
Example 2:
  <SequenceOfBACnetAuthorizationExemption>
    <BACnetAuthorizationExemption>passback</BACnetAuthorizationExemption>
    <BACnetAuthorizationExemption>occupancyCheck</BACnetAuthorizationExemption>
    <BACnetAuthorizationExemption>accessRights</BACnetAuthorizationExemption>
  </SequenceOfBACnetAuthorizationExemption>
</Value>
