accessCredential.authorizationExemptions |
The authorization checks from which this credential is exempt. When a credential is exempt from an authorization check, the access attempt shall not be denied due to this authorization criterion.
Property authorizationExemptions of object accessCredential can be read and written using a single IOTag.
accessCredential-<objectAddress>.authorizationExemptions |
<type> = 32 |
<property> = 364 |
A character string containing an XML with a value of type <SequenceOfBACnetAuthorizationExemption>.
