SequenceOfBACnetAuthenticationPolicy
This XML representation of complex data is used by the following objects/properties:
•accessPoint.authenticationPolicyList
XML Schema
  <xs:complexType name="SequenceOfBACnetAuthenticationPolicy">
    <xs:sequence>
      <xs:element minOccurs="0" maxOccurs="unbounded" name="BACnetAuthenticationPolicy" type="BACnetAuthenticationPolicy" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="SequenceOfBACnetAuthenticationPolicy" />
</xs:schema>
Examples
Example 1:
  <SequenceOfBACnetAuthenticationPolicy />
</Value>
Example 2:
  <SequenceOfBACnetAuthenticationPolicy>
    <BACnetAuthenticationPolicy>
      <Policy />
      <OrderEnforced>true</OrderEnforced>
      <Timeout>1234</Timeout>
    </BACnetAuthenticationPolicy>
      <Policy>
        <Policy_Item>
          <CredentialDataInput>
            <DeviceIdentifier>device-502</DeviceIdentifier>
            <ObjectIdentifier>device-503</ObjectIdentifier>
          </CredentialDataInput>
          <Index>1237</Index>
        </Policy_Item>
      </Policy>
      <Timeout>1238</Timeout>
      <Policy>
        <Policy_Item>
            <DeviceIdentifier>device-506</DeviceIdentifier>
            <ObjectIdentifier>device-507</ObjectIdentifier>
          <Index>1241</Index>
        </Policy_Item>
      </Policy>
      <Timeout>1242</Timeout>
  </SequenceOfBACnetAuthenticationPolicy>
</Value>
Example 3:
      <Policy>
        <Policy_Item>
            <DeviceIdentifier>device-510</DeviceIdentifier>
            <ObjectIdentifier>device-511</ObjectIdentifier>
          <Index>1245</Index>
        </Policy_Item>
        <Policy_Item>
            <DeviceIdentifier>device-513</DeviceIdentifier>
            <ObjectIdentifier>device-514</ObjectIdentifier>
          <Index>1248</Index>
        </Policy_Item>
        <Policy_Item>
            <DeviceIdentifier>device-516</DeviceIdentifier>
            <ObjectIdentifier>device-517</ObjectIdentifier>
          <Index>1251</Index>
        </Policy_Item>
      </Policy>
      <Timeout>1252</Timeout>
      <Policy>
        <Policy_Item>
            <DeviceIdentifier>device-520</DeviceIdentifier>
            <ObjectIdentifier>device-521</ObjectIdentifier>
          <Index>1255</Index>
        </Policy_Item>
      </Policy>
      <Timeout>1256</Timeout>
      <Policy>
        <Policy_Item>
            <DeviceIdentifier>device-524</DeviceIdentifier>
            <ObjectIdentifier>device-525</ObjectIdentifier>
          <Index>1259</Index>
        </Policy_Item>
      </Policy>
      <Timeout>1260</Timeout>
</Value>
