accessPoint.authenticationPolicyList |
Specifies the authentication policies defined for this Access Point.
Property authenticationPolicyList of object accessPoint can be read and written using a single IOTag.
accessPoint-<objectAddress>.authenticationPolicyList |
<type> = 33 |
<property> = 258 |
A character string containing an XML with a value of type <SequenceOfBACnetAuthenticationPolicy>.
