SequenceOfBACnetAssignedLandingCalls
This XML representation of complex data is used by the following objects/properties:
•lift.assignedLandingCalls
XML Schema
  <xs:complexType name="SequenceOfBACnetAssignedLandingCalls">
    <xs:sequence>
      <xs:element minOccurs="0" maxOccurs="unbounded" name="BACnetAssignedLandingCalls" type="BACnetAssignedLandingCalls" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="SequenceOfBACnetAssignedLandingCalls" />
</xs:schema>
Examples
Example 1:
  <SequenceOfBACnetAssignedLandingCalls />
</Value>
Example 2:
  <SequenceOfBACnetAssignedLandingCalls>
    <BACnetAssignedLandingCalls>
      <LandingCalls />
    </BACnetAssignedLandingCalls>
      <LandingCalls>
        <LandingCalls_Item>
          <FloorNumber>33</FloorNumber>
          <Direction>none</Direction>
        </LandingCalls_Item>
      </LandingCalls>
      <LandingCalls>
        <LandingCalls_Item>
          <FloorNumber>35</FloorNumber>
          <Direction>up</Direction>
      </LandingCalls>
  </SequenceOfBACnetAssignedLandingCalls>
</Value>
Example 3:
      <LandingCalls>
        <LandingCalls_Item>
          <FloorNumber>37</FloorNumber>
          <Direction>upAndDown</Direction>
        <LandingCalls_Item>
          <FloorNumber>39</FloorNumber>
        <LandingCalls_Item>
          <FloorNumber>41</FloorNumber>
      </LandingCalls>
      <LandingCalls>
        <LandingCalls_Item>
          <FloorNumber>43</FloorNumber>
      </LandingCalls>
      <LandingCalls>
        <LandingCalls_Item>
          <FloorNumber>45</FloorNumber>
      </LandingCalls>
</Value>
