lift.assignedLandingCalls |
Represent the current landing calls and their direction for the lift represented by this object. Each array element represents the list of assigned landing calls for the door of the car assigned to this array element.
Property assignedLandingCalls of object lift can be read and written using a single IOTag.
lift-<objectAddress>.assignedLandingCalls |
<type> = 59 |
<property> = 447 |
A character string containing an XML with a value of type <SequenceOfBACnetAssignedLandingCalls>.
