SequenceOfBACnetAddressBinding
This XML representation of complex data is used by the following objects/properties:
•device.deviceAddressBinding
•networkPort.manualSlaveAddressBinding
•networkPort.slaveAddressBinding
XML Schema
  <xs:complexType name="SequenceOfBACnetAddressBinding">
    <xs:sequence>
      <xs:element minOccurs="0" maxOccurs="unbounded" name="BACnetAddressBinding" type="BACnetAddressBinding" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="SequenceOfBACnetAddressBinding" />
</xs:schema>
Examples
Example 1:
  <SequenceOfBACnetAddressBinding />
</Value>
Example 2:
  <SequenceOfBACnetAddressBinding>
    <BACnetAddressBinding>
      <DeviceIdentifier>device-501</DeviceIdentifier>
      <DeviceAddress>
        <NetworkNumber>7635</NetworkNumber>
        <MacAddress>00010203040506070809</MacAddress>
      </DeviceAddress>
    </BACnetAddressBinding>
      <DeviceIdentifier>device-503</DeviceIdentifier>
      <DeviceAddress>
        <NetworkNumber>7637</NetworkNumber>
        <MacAddress>FF</MacAddress>
      </DeviceAddress>
      <DeviceIdentifier>device-505</DeviceIdentifier>
      <DeviceAddress>
        <NetworkNumber>7639</NetworkNumber>
      </DeviceAddress>
  </SequenceOfBACnetAddressBinding>
</Value>
