networkPort.manualSlaveAddressBinding |
Describes the manually configured set of slave devices for which this device is acting as a Slave Proxy. This property shall be present and writable if the device is capable of performing the functions of a Slave-Proxy device on this port.
Property manualSlaveAddressBinding of object networkPort can be read and written using a single IOTag.
networkPort-<objectAddress>.manualSlaveAddressBinding |
<type> = 56 |
<property> = 170 |
A character string containing an XML with a value of type <SequenceOfBACnetAddressBinding>.
