SequenceOfBACnetAccessRule
This XML representation of complex data is used by the following objects/properties:
•accessRights.negativeAccessRules
•accessRights.positiveAccessRules
XML Schema
  <xs:complexType name="SequenceOfBACnetAccessRule">
    <xs:sequence>
      <xs:element minOccurs="0" maxOccurs="unbounded" name="BACnetAccessRule" type="BACnetAccessRule" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="SequenceOfBACnetAccessRule" />
</xs:schema>
Examples
Example 1:
  <SequenceOfBACnetAccessRule />
</Value>
Example 2:
  <SequenceOfBACnetAccessRule>
    <BACnetAccessRule>
      <TimeRangeSpecifier>specified</TimeRangeSpecifier>
      <TimeRange>
        <ObjectIdentifier>device-502</ObjectIdentifier>
        <PropertyIdentifier>action</PropertyIdentifier>
        <PropertyArrayIndex>1237</PropertyArrayIndex>
        <DeviceIdentifier>device-505</DeviceIdentifier>
      </TimeRange>
      <LocationSpecifier>all</LocationSpecifier>
      <Location>
        <DeviceIdentifier>device-507</DeviceIdentifier>
        <ObjectIdentifier>device-508</ObjectIdentifier>
      </Location>
      <Enable>true</Enable>
    </BACnetAccessRule>
    <BACnetAccessRule>
      <TimeRange>
        <ObjectIdentifier>device-510</ObjectIdentifier>
        <PropertyIdentifier>apduSegmentTimeout</PropertyIdentifier>
        <PropertyArrayIndex>1245</PropertyArrayIndex>
        <DeviceIdentifier>device-513</DeviceIdentifier>
      </TimeRange>
      <Location>
        <DeviceIdentifier>device-515</DeviceIdentifier>
        <ObjectIdentifier>device-516</ObjectIdentifier>
      </Location>
    </BACnetAccessRule>
    <BACnetAccessRule>
      <TimeRange>
        <ObjectIdentifier>device-518</ObjectIdentifier>
        <PropertyIdentifier>controlledVariableReference</PropertyIdentifier>
        <PropertyArrayIndex>1253</PropertyArrayIndex>
        <DeviceIdentifier>device-521</DeviceIdentifier>
      </TimeRange>
      <Location>
        <DeviceIdentifier>device-523</DeviceIdentifier>
        <ObjectIdentifier>device-524</ObjectIdentifier>
      </Location>
    </BACnetAccessRule>
  </SequenceOfBACnetAccessRule>
</Value>
