accessRights.negativeAccessRules |
Specifies the negative access rules.
Property negativeAccessRules of object accessRights can be read and written using a single IOTag.
accessRights-<objectAddress>.negativeAccessRules |
<type> = 34 |
<property> = 288 |
A character string containing an XML with a value of type <SequenceOfBACnetAccessRule>.
