Reading a Load Profile |
Reading a Load Profile of a meter is transferring and interpreting channel measurements with consumption data. Users generally refer to Load Profile collecting as Mass Memory Reading. To perform a Load Profile reading, execute the next procedures.
1.Write to a Start Read Tag (1, 64, 0, 0) with two Elements with the initial and final date and time to start the transfer process.
2.If needed, monitor the transfer by reading the Status Read Tag (2, 64, 0, 0).
3.When the transfer ends, read the Read Table Tag configured for the ST-64 table (0, 64, 0, 0).
4.If needed, read the Read Profile Channels Tag (4, 0, 0, 0) to interpret each one of the Load Profile channels.
