Start Read
Start Read
Write-Only
N1/B1
1 (one)
N2/B2
Number of an ANSI C12.19 table
N3/B3
Not used, leave it in 0 (zero)
N4/B4
If the value of the N2/B2 parameter is equal to 64, this Tag must be a Block with two Elements, indicating a period of time for a data collecting.
•Element 1: Initial date and time of data collecting in TIME format
•Element 2: Final date and time of data collecting in TIME format
For all other tables, this Tag must be a PLC type and its content of the Value property is not relevant. Tables requiring a writing to command readings are ST-12, ST-15, ST-16, ST-62, ST-64, ST-74, ST-76, and MT-17 (Elster).
