Read Profile Channels
Reading and Writing
B1
4 (four)
B2
Not used, leave it in 0 (zero)
B3
B4
Size
6 (six)
A Block Tag with six Elements that performs a profile reading of each one of the channels. If there is data, a list with N blocks is returned, where N is the number of data blocks read. Otherwise, returns an empty list.
Writing any value to this Tag forces the enumeration of the channels, which are added to the list of channels to read during the execution of this Tag's reading.
•Element 1: Profile index
•Element 2: Measurement unit. For more information, please check the Table of quantities
•Element 3: Quadrant
•Element 4: Net flow. Possible values are 0: Absolute power per time unit or 1: Net delivered or received
•Element 5: Segmentation
•0: Not phase-related or n/a
•1: Phase A to B
•2: Phase B to C
•3: Phase C to A
•4: Neutral to ground or no information
•5: Phase A to Neutral
•6: Phase B to Neutral
•7: Phase C to Neutral
•Element 6: Scale factor
Table of quantities
Option
Quantity
0
Active power (W)
1
Reactive power (VAR)
2
Apparent power (VA)
3
Phasor power (VA = sqrt(W² + VAR²))
4
Quantity power Q(60)
5
Quantity power Q(45)
6
Phasor reactive power
7
Distortion volt-amperes
8
RMS voltage
9
Average voltage
10
RMS voltage squared
11
Instantaneous voltage
12
RMS current
13
Average current
14
RMS current squared
15
Instantaneous current
16
Total harmonic distortion, voltage (IEEE)
17
Total harmonic distortion, current (IEEE)
18
Total harmonic distortion, voltage (Industry Canada)
19
Total harmonic distortion, current (Industry Canada)
20
Voltage phase angle
21
Voltage phase angle XY, in which X and Y are phases defined in phase selector
22
Current phase angle
23
Current phase angle XY, in which X and Y are phases defined in phase selector
24
Power Factor, computed using apparent power
25
Power Factor, computed using phasor power
26
Average power factor
29
Time of day
30
Date
31
Time of day and date
32
Interval Timer
33
Frequency
34
Counter
35
Sense Input
36
Pulse output form A
37
Pulse output form B
38
Pulse output form C
39
Zero flow duration
40
Voltage sag
41
Voltage swell
42
Power outage
43
Voltage excursion low
44
Voltage excursion high
45
Normal voltage level
46
Phase voltage phase imbalance
47
Voltage total harmonic distortion excess
48
Current total harmonic distortion excess
49
Power Outage (End Device)
50
Number of power outages
51
Number of demand resets
52
Number of times programmed
53
Number of minutes on battery carryover
54
Number of inversion tampers
55
56
Number of removal tampers
57
Number of reprogramming tampers
58
Number of power loss tampers
59
Number of reverse rotation tampers
60
Number of physical tampers
61
Number of encoder tampers
62
Number of watchdog timeouts
63
Number of diagnostic alarm
